cant get it hot enough
发表于 2021-9-1 00:50:47 | 显示全部楼层 |阅读模式
I just got a century ac/dc welder I have welded before I cant seem to get any pentration, Im welding in both straight an reverse polarity  ive got the welder maxed at 140 and still cant burn through I change one thing on the welder i made the supply cord longer i use 10-3 wire that what was on it when i got it. ive used 3/32, 1/8 rod 6011 6013 and im welding in dc, tryed ac but i didnt have any patients any suggestion would be helpfull guys thank.
Reply:Is this machine 110 or 220?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:its 220
Reply:How much longer did you make the cord?Yup
Reply:15 feet.
Reply:how thick is the metal your trying to weldBTS Welding
Reply:1/8 th inch
Reply:a 140 amps dc is way too much for 1/8 6011 and a little too warm for 6013. start check all of your connections. are you trying to weld on old crusty rust? maybe the range switch weny bad.
Reply:Originally Posted by tresia 140 amps dc is way too much for 1/8 6011 and a little too warm for 6013. start check all of your connections. are you trying to weld on old crusty rust? maybe the range switch weny bad.
Reply:i screwed around with it again this evening same thing happend on ac but the guy i got the welder from had some 1/16 rod so i tryed that and it did burn through the metel and a peice of 1/2 inch black pipe with a desent weld tried to cap it with 3/32 and no go.
GMT+8, 2025-12-20 13:03 , Processed in 0.069870 second(s), 18 queries .
