mig welding trouble
发表于 2021-9-1 00:50:44 | 显示全部楼层 |阅读模式
i am currently having a problem with my mig welderthe machine was welding great yesterday no problems at alli exchanged the gas bottle today and now when i try to lay a bead down it just splatters and the weld bead doesnt stay in the direction im welding it seems to run(almost drip) and not penetratethe wire is the same the welding area and ground are are extremely cleanthe gun is shooting out gasbut it welds like it is getting no gasi am running argon/co2 (what i had before and what i exchanged for today)i dont know whats wrongcould the gas be bad or whatany help appreciated
Reply:Did  you read the label on the new gas bottle?Does the machine have recommended settings?  What machine are you using?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Could be a bad bottle. It has happened before. Did you check the gun lead to make sure their are no damaged spots. Also what is your flow rate at. Should only be 20 to 30. You may have more pressure in the tank which might increase the flow rate to much for your regulator setting.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:how many cfms of gas are you using?http://www.aloumac.ca/
Reply:Originally Posted by Matthewhow many cfms of gas are you using?
Reply:Hello and welcome to the forum.My guess is it's the wrong gas and check the label. As others have suggested, too much flow or a leak could also cause the issues, but since it worked before well I assume and now dosen't, I'd look at a bad bottle of gas.
Reply:thanks for all the help guys ill double check the label on the bottleif im welding mild steel is it correct to use 25% co2 and 75% argon
Reply:75/25 is best for mig.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Look up this post and see the pics at the end of it, I had a similar problem...http://weldingweb.com/vbb/showthread.php?t=21393I hope it helps,
GMT+8, 2025-12-20 13:02 , Processed in 0.100791 second(s), 18 queries .
