Parts needed.
发表于 2021-9-1 00:50:34 | 显示全部楼层 |阅读模式
I just bought a 6.5 HP 80 gallon, black max air compressor for 140.00.  But I need to get a new motor for it. Do you know where I should look for a new one.Thanks in advance.
Reply:Don't know if it will help, but every time I need a motor, I go to Grainger, seems like they've got them all.Best of luckI r 2 a perfessional
Reply:Originally Posted by kbnitDon't know if it will help, but every time I need a motor, I go to Grainger, seems like they've got them all.Best of luck
Reply:Grainger, McMaster-Carr, Tractor Supply, Surplus Center, should all have applicable electric motors.  At retail, retail, retail, and surplus prices, in that order.Or scour e-bay or craigslist and find a motor or a compressor with a junked tank but good motor.  The best laid schemes ... Gang oft agley ...
Reply:Have you looked into getting it repaired?Contemporary Metal Wall Art and Abstract Metal Art
Reply:I only get stuff from Grainger that I can't get anywhere else. Man are they high priced. Make sure it is big enough and that it is compressor duty.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Originally Posted by georgiametalartHave you looked into getting it repaired?
Reply:Ok, here's what you need to do. look on the motor and see if is a standard frame motor or not. There should be a data plate on the motor. It should such info such as rpm, horse power, frame size, voltage,ect. If it has all this info give this info to grainger or any motor shop and they should be able to fix you up. If it lacks info such as frame size it maybe an OEM spec motor in that case you'll have to get it from the manufacture or you'll have to adapt a standard motor to fit. This could require different many mods to pull this off if it is an OEM spec motor.
GMT+8, 2025-12-20 14:11 , Processed in 0.069386 second(s), 18 queries .
