Best starter welding project?
发表于 2021-9-1 00:50:25 | 显示全部楼层 |阅读模式
I just recently learned how to weld. I have a large shop, and I want to take on a project that I can put my welding to a good use. I would like to build something with an engine in it. So far I've heard people say that I should build a go cart. Any othe suggestions?
Reply:start with a welding table.  you'll need something to weld on.
Reply:Originally Posted by Stone_Elvisstart with a welding table.  you'll need something to weld on.
Reply:Barstool racerGo kartSand railEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Mini-Chopper..... Kinda like this... http://www.baronbob.com/kikker-hardknock.htm   I see they started using a 200cc engine now too.. You could copy the basics and use a trashed MC of any type for parts...just build a frame to suit.
Reply:Mini bikeMini Chopperjust make sure your skills and equipment is up to par for the job. You do not want a joint to break at 30mph.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:How about some ideas for non-engine projects? I like the ideas so far.
Reply:http://www.millerwelds.com/interests/projects/Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:If you want to build a chopper or mini-chopper---- Do some research  http://chopperbuilders.net/neatstuff/index.html   best information on the www They have plans for a frame jig--- great first project(safe & you won't get killed)---when you get done with it you can always sell it..
Reply:What do you need around the shop, house or yard? Think of some thing you can use afterwards....do you have a welder cart?If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I'm with SWells,Every new welder's first welding job should be a cart for the welding machine.I r 2 a perfessional
Reply:I think I'm going with the table design on http://www.millerwelds.com/interests...welding-table/, do you think the 3/8' steel plate could be cut with an acetylene torch rather than a plasma cutter? With that design, what is the point of the plasma grate?
Reply:Also, what are some good projects under a $100 budget?
Reply:I'm sorely tempted to inform you that torch cutting that thick metal is not possible...but it is!!  The grate is meant to support the material being cut, while allowing slag to fall through. It works with most flame/plasma cutting systems.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by patm1313Do you think the 3/8' steel plate could be cut with an acetylene torch rather than a plasma cutter?
Reply:Welding CartBeer/Pop can crusherchop saw stand4x6 band saw cart Rack for stockstand for grinding wheel
Reply:Originally Posted by Craig in DenverYes.  Source: Modern Welding by Althouse-Turnquist-Bowditch-Bowditch
Reply:Originally Posted by RojodiabloWow, that's a thick block of steel!!!
Reply:How about a log splitter? Easy to find parts to make em at nrothern tool or harborfreight..and can be sold easily if you dont split wood.These are pics of homeade units..Total cost to build with new engine is around $1000 or cheaper if you can make the hydro tanks and find a used hydro cylinder for the ram.This is best of best both worlds wheels and engine!!!!Go build one!Last edited by goodoleboy; 08-09-2008 at 08:41 AM.
Reply:Originally Posted by tanglediverI'm sorely tempted to inform you that torch cutting that thick metal is not possible...but it is!!  The grate is meant to support the material being cut, while allowing slag to fall through. It works with most flame/plasma cutting systems.
Reply:Originally Posted by goodoleboyHow about a log splitter? Easy to find parts to make em at nrothern tool or harborfreight..and can be sold easily if you dont split wood.These are pics of homeade units..Total cost to build with new engine is around $1000 or cheaper if you can make the hydro tanks and find a used hydro cylinder for the ram.This is best of best both worlds wheels and engine!!!!Go build one!
Reply:What's the basket for on the side of that log splitter? It has steering and a rearend.... Self-propelled? Interesting design.
Reply:Originally Posted by patm1313But then what is stopping the flame/plasma torch from cutting through the grate?
Reply:Originally Posted by mudbugoneWhat's the basket for on the side of that log splitter? It has steering and a rearend.... Self-propelled? Interesting design.
Reply:I agree on the custom welding cart, myself.  I have to keep my welder outside because I don't have a garage as of yet.  I keep it in a steel, locked cabinet at the time, but I am going to build a locking, covered cart for it so I don't have to drag it out EVERY time I want to use it.  Use the forum search and check out a couple of the welding carts users here have made - some top-notch work!Have a Jeep Cherokee?  Click Here!Originally Posted by tresiThe preheat doesn't travel through to the grate. it will get a bit nicked up but it will last for years, Kinda like if you try to flame cut through 2 pieces of metal. the second piece doesn't cut.
Reply:And another question, does molten metal coming off a flame cutter stick to aluminum? I know that when MIG welding your weld won't stick to aluminum, so is the same the case with flame cutting?
Reply:What would be a good project to use the engine from a chainsaw for? I was going to build something with that engine, and never got around to it.
Reply:Tropical Drink Blender...
Reply:A blender would be nice but:A. I already have oneB. I would be afraid of a blender with an engine like this in it.
Reply:Mount it on a skateboard and hold on tight!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Originally Posted by SWellsMount it on a skateboard and hold on tight!
Reply:Yeah, your right...sorry, mount it on your bike instead!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Originally Posted by SWellsYeah, your right...sorry, mount it on your bike instead!
Reply:Perhaps you could design a portable winch around that chainsaw engine?WeldingWeb forum--now more sophomoric banter than anything else!
Reply:Originally Posted by 69 chevyPerhaps you could design a portable winch around that chainsaw engine?
Reply:How bout a cart for your stock.much easier to move around a few hundred pounds of steel when it is motorized.or may be the cart has a lift bed to reach the bed of a truck?ESAB MIGMASTER 250and a No Name AD Helmet from my Local Supplier...In the only color that matters...CAMO
GMT+8, 2025-12-20 14:01 , Processed in 0.111002 second(s), 18 queries .
