oxy-acetylene regulator pressures?
发表于 2021-9-1 00:50:15 | 显示全部楼层 |阅读模式
It's been a long time since I've had to do a lot of burning on heavy steel. I"m probally wrong but I remember setting acty, regulator on 7psi and the oxy regulator on twenty psi. I am burning 1/4 inch, maybe a litte thicker, and am having trouble. Are my settings correct, or should I use different pressures. Oh yeh, I'm using a Harris tourch with a #3 tip. Anyone have advice?          Thanks, Wesley(Wagin)Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Originally Posted by waginIt's been a long time since I've had to do a lot of burning on heavy steel. I"m probally wrong but I remember setting acty, regulator on 7psi and the oxy regulator on twenty psi. I am burning 1/4 inch, maybe a litte thicker, and am having trouble. Are my settings correct, or should I use different pressures. Oh yeh, I'm using a Harris tourch with a #3 tip. Anyone have advice?          Thanks, Wesley(Wagin)
Reply:Assuming you are cutting and not welding:Your pressure setting look about right for the metal thickness. However, they seem to be way off for the tip size and the tip size is way off for the material thickness.A #3 Harris tip is meant for cutting 2-3" thick steel. For cutting 1/4" the recommended tip size is a 00.Here is a chart for material thickness, tip size, and recommended pressures (it's actually a Victor chart, but the sizes etc. pretty much match with Harris tips):Visit Tensaiteki.com
Reply:Uh-oh. Are we cutting or welding?9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Cutting tip #3, series 2490 or 6290 is for 2 to 3" thick material.Welding tip #3 in series 23-A-90, 1390 or 5090 is for  1/16" thickness.For  an equal pressure torch using those above tips:For cutting, you need a size 00 with 5 to 10 psi acetylene, 20 to 30 psi O2.For welding, you need #7 tip with 7 psi of each gas.This data is from an old Harris catalog (No.746), undated but probably from mid 70's..
Reply:thank ya'll for the advice. Got a #1 tip today,(was the smallest available), and it performed much better. After pondering this cutting problem, and the great info,  I recalled that I used a #00 tipp for most everything during my construction and fab. days.    thanks again.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:I've always had a Harris, and a lot of guys have suggested that a Victor might be better.  I've never run one so I don't know.It's sometimes a nuisance running the Harris because the preheat flame is so short.  You have to pretty darn near touch the iron with it.  Tip needs cleaning more often too.  I guess that's because of the short preheat.Try to stick with genuine Harris tips if your supplier can get them.  I've tried other brands which are supposed  to work on the Harris but they never seem to work right.A 2/0 tip works great on 3/16 to 1/4, 3/8 if you slow down.  Generally I like a 0 tip for 3/8 to 1/2.  I seldom cut much thicker stuff.Don't drop any iron on yer tootsies.
Reply:Originally Posted by farmersammI've always had a Harris, and a lot of guys have suggested that a Victor might be better.  I've never run one so I don't know.It's sometimes a nuisance running the Harris because the preheat flame is so short.  You have to pretty darn near touch the iron with it.  Tip needs cleaning more often too.  I guess that's because of the short preheat.Try to stick with genuine Harris tips if your supplier can get them.  I've tried other brands which are supposed  to work on the Harris but they never seem to work right.A 2/0 tip works great on 3/16 to 1/4, 3/8 if you slow down.  Generally I like a 0 tip for 3/8 to 1/2.  I seldom cut much thicker stuff.Don't drop any iron on yer tootsies.
GMT+8, 2025-12-20 14:02 , Processed in 0.077593 second(s), 18 queries .
