what material
发表于 2021-9-1 00:50:14 | 显示全部楼层 |阅读模式
so i have been welding on scrap steel and now i want to do a real project so i found the closest metal place to my house http://www.metalsupermarkets.com/MSC-home.aspxnow Im confused on what metal to get I am planning on making a lacrosse goal I have a 110  mig welder
Reply:ROUND STRUCTURAL ASTM A-500 GRADE B CSA G40.21 50W.125 should do it.and then whatever size tubing the Goal is made out of.Click on:Steel Tube & PipeStep 1. Steel Tube & PipeStep 2.  CARBON STEEL TUBINGStep 3. ROUND STRUCTURAL ASTM A-500 GRADE B CSA G40.21 50WStep 4. Select sizeIf you know the cut lengths you may as well check and see what they charge to cut the stock otherwise ya gotta haul 10 footers or a 20 footer.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1ROUND STRUCTURAL ASTM A-500 GRADE B CSA G40.21 50W.125 should do it.:
Reply:Originally Posted by Joe HI gasped, at first, to the .125 part. I thought "jeeez man, a little overkill don't ya think"But yeah, frst project, definately get the .125. Nice and easy to work with, real forgiving.
Reply:cool thanks for the helpafter i finish i could start selling them and make the money i spent on my welder back
Reply:Originally Posted by zafocool thanks for the helpafter i finish i could start selling them and make the money i spent on my welder back
Reply:yeah the nets are pretty expencivehow much do you think the steel should cost
Reply:Zafo, for first projects, I suggest you build small stuff you can make with metal that is good, and clean, but in remnant barrels or scrap racks. I can usually find lots of sq. tube, angle, plate, etc. in lengths from 2ft. to 10ft. Almost all my plate projects are made with rems of various sizes. I am not interested in keeping a 10ftx 3ft sheet around if I don't need it.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Originally Posted by zafoyeah the nets are pretty expencivehow much do you think the steel should cost
Reply:so on the goal for the bars that are on the ground i want to make them flat bar 3" x 1/4 x 8'so what would be the path to take to find them
Reply:Originally Posted by zafoso on the goal for the bars that are on the ground i want to make them flat bar 3" x 1/4 x 8'so what would be the path to take to find them
Reply:I can't stand my local metalsupermarket - their pricing is out of this world - make sure you bring your first born.  Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Originally Posted by VipernutI can't stand my local metalsupermarket - their pricing is out of this world - make sure you bring your first born.
GMT+8, 2025-12-20 14:09 , Processed in 0.101015 second(s), 18 queries .
