Hobart wire feed question
发表于 2021-9-1 00:50:06 | 显示全部楼层 |阅读模式
I have just bought a Beta Mig 200 and have a wire feed question.I can adjust my voltage with no problem, but no matter what setting I go to on the voltage 1 to 8 ( that will alter my penetration) but my wire feed will only give me a good weld with the wire feed on # 1.  If I go any higher it will not melt and just push from the work with a lot of pops.  My input voltage was measured with the welder actually welding and it holds at 220 volts. On the #1 of the wire feed setting there is a good crackle and is even and the weld really looks good but I do not think I am getting the penetration that I should be getting. This test is on 1/4" flat iron,very clean. The Hobart is on the LOW setting, as is called for in the instructions, but they also say I should be able to go up to 4 or 5 on the wire speed setting?It seems that I may not be getting the correct amperage increase with the speed of the wire increase??  I do not have a manual and Hobart no longer has it on its web site, so I am going on the information on the back of the wire wheel panel cover.By the way I cannot find a serial number on the unit?  where is it supposed to be?Larrywelder
GMT+8, 2025-12-20 13:59 , Processed in 0.169964 second(s), 18 queries .
