mig welder with auto-set
发表于 2021-9-1 00:49:59 | 显示全部楼层 |阅读模式
Can someone tell me if there is a lot of advantage for having the auto-set on the mig welder especially for someone with out a lot of experience. thanks for your advice
Reply:Isn't there someone out there that can answer this question.  thanks
Reply:I have a Miller 140 with Autoset and I am really happy with it. I have been using it for over a year with what I consider good results. As the AirGas salesman told me, he has been a welder for 15 years and he could not set the machine any better than what the Autoset will do. Of course you can still set the welder manually, and for aluminum, etc. you need to, but for mild steel it is nice to simply set the wire size and metal thickness and start welding.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by wheelerbuffyCan someone tell me if there is a lot of advantage for having the auto-set on the mig welder especially for someone with out a lot of experience. thanks for your advice
GMT+8, 2025-12-20 14:09 , Processed in 0.098704 second(s), 18 queries .
