Plasma welding
发表于 2021-9-1 00:49:54 | 显示全部楼层 |阅读模式
Hi there does any one know whether you can weld with a plasma cutter,I have a ac/dc tig, arc and plasma welder (200amps) and was wandering whether i can also use the plasma torch for welding as well as cutting, does any 1 know if so it would be great
Reply:Nope.A plasma cutter cutter cuts.A plasma welder welds.They both use plasma, but in different ways.  The best laid schemes ... Gang oft agley ...
GMT+8, 2025-12-20 15:30 , Processed in 0.101980 second(s), 18 queries .
