MC grade welding rod
发表于 2021-9-1 00:49:49 | 显示全部楼层 |阅读模式
I'm welding 4130 tubing and was interested in using the metallurgically controlled welding rod. The type I can find for example is Turbaloy 4130 or AMS 6457. Would these require post heat treating? I use ER80 rod now and it does not require post heat treating. Also would this type of filler rod not have the elasticity required (would it be too brittle)?
Reply:If you're welding 4130 material with a 4130 based filler, PWHT is absolutely necessary.  Ductility is considerably less than mild steel fillers.  This is why the mild steel fillers are commonly used for aircraft, automotive/racing use, etc.
GMT+8, 2025-12-20 14:13 , Processed in 0.343887 second(s), 18 queries .
