hobart 250 won't strike a arc
发表于 2021-9-1 00:49:48 | 显示全部楼层 |阅读模式
Hi I have a hobart 250 beta mig model 7189-1. It worked fine the last time i used it, about 8 months ago. Just tried to use it,and it won't strike a arc. The reostat is real stiff. It feeds wire. Anyone have any ideas? I've have had this welder about 12 years never had this problem before. Thanks
Reply:Post removedLast edited by chrispc66; 09-17-2008 at 12:31 AM.
Reply:Possible blown fuse somewhere ?If not - electrician !Cheers and good luck
GMT+8, 2025-12-20 14:21 , Processed in 0.089458 second(s), 18 queries .
