useful life of 110 volt mig welders
发表于 2021-9-1 00:49:47 | 显示全部楼层 |阅读模式
How many years or how much use before a mig welder needs to be replaced?  I am looking at a Lincoln pro mig 135.  The guy said it is about 5 years old and he used it for a landrover restoration and some projects around his house.  He is asking $300 and includes the gas cylinder (the welding store that refills the tank is close by).  He said the welder works as good as the day he bought it.  Is this a good deal and what if any repairs will need to be made in the future?  Thanks in advance for any and all replies.  Jim
Reply:A good quality brand name wire feeder unit with 5 years of home owner use on it has a lot of wire left to feed. I would be a bit worried about a 5 year old unit that was used in a body shop though. $300 with bottle sounds pretty darn good. Can't think of any repairs you should expect. Gas solinodes do fail on occasion, Wire feed motor will wear with time, but should still be fine. Main PS boards, you just never know, but don't hear of them blowing often in these units.Maybe new feed roller and cable liner, but I have been using mine for 5 years at a bit more than a home use level and they are still good.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
Reply:I have a 90 amp Miller Sidekick that was made in 1987 and still welds like a fool.
Reply:My lincoln 100 was 9 years ols when I sold it, I wish I still had it. It works at a friend of mines' garage still today.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:A new jug is 150.00So you are getting the Lincoln for 150.00Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by retire2$  He said the welder works as good as the day he bought it.
Reply:Snatch it up...... Originally Posted by RojodiabloMy lincoln 100 was 9 years ols when I sold it, I wish I still had it. It works at a friend of mines' garage still today.
Reply:Originally Posted by David RSnatch it up......I bought my SP100 around 1987.  Still got it, still use it about an 8" roll of wire a year or less.I replaced the gun once and a few liners.  It won't weld aluminum for me.The arc with .023 and C/25 is awesome.David
GMT+8, 2025-12-20 14:13 , Processed in 0.093074 second(s), 18 queries .
