1st try with new spool gun ???
发表于 2021-9-1 00:49:42 | 显示全部楼层 |阅读模式
The corner weld was at 665 ipm and 21v and the filet(I think) was at 450ipm an 24v on 1/4 with 030 4043 wire on a esab mt250 spoolgun and mm260 power with 100% argon.These are close to the settings under the cover.Both were spraying well except for the last couple of inches on the inside corner,probably operator error on distance. I'm lost on this stuff but it sure is interesting.I'm not even going to show anyone my first tig welds they are sick.Help with any info please.Thanks Ken Attached Images
Reply:Originally Posted by JackLeggThe corner weld was at 665 ipm and 21v and the filet(I think) was at 450ipm an 24v on 1/4 with 030 4043 wire on a esab mt250 spoolgun and mm260 power with 100% argon.These are close to the settings under the cover.Both were spraying well except for the last couple of inches on the inside corner,probably operator error on distance. I'm lost on this stuff but it sure is interesting.I'm not even going to show anyone my first tig welds they are sick.Help with any info please.Thanks Ken
Reply:I push with the spoolgun and keep the nozzle close.  Welds look good.  Keep at it.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Here's a post about spoolgun setup and use, interesting if a bit testy, http://weldingweb.com/vbb/showthread.php?t=19441 that might be helpful, JackLegg.ScottMiller XMT 350 CC/CV w/gas solenoid opt.Miller S-22A wirefeederBernard 400A "Q" gunMiller Spoolmatic 30A / WC-24C-K 200A torch/gas lensWeldcraft WC-18 watercooled torchHypertherm Powermax 30Victor O/A
GMT+8, 2025-12-20 14:13 , Processed in 0.096859 second(s), 18 queries .
