welding sch. 40
发表于 2021-9-1 00:49:35 | 显示全部楼层 |阅读模式
need to make gates of sch. 40 pipeshould i mig or tig them
Reply:I'd mig em. They will warp less and you will get done faster. Just my opinion.GeraldHave a nice dayhttp://www.weldingdata.com/
Reply:Originally Posted by ed macneed to make gates of sch. 40 pipeshould i mig or tig them
Reply:yeah i would mig it. if you can run everything downhill. a lot less heat that way.
Reply:Is your mig big enuf f?   If so mig it . with the time you save ,you spend the next 3 days  fishing..   lol  good luck Daye
Reply:This may help or may not. It is a page I made a while back regarding different processes. It is by no means all inclusive but it may help you.http://www.weldingdata.com/processopinions.htm Have a nice daygeraldHave a nice dayhttp://www.weldingdata.com/
Reply:how big of a mig do you need how much voltage
Reply:Well, the wall thickness is going to vary with the pipe diameter...You're not big on giving details with your questions are you?
Reply:1 3/8 sch. 40 i need to notch and weld themi have a mm 251 30th e70 wire
Reply:1" Schedule 40 is the actual size if the OD is 1.315.GMAW would work fine. It is really more dependent upon your skills and abilities.Have a nice dayhttp://www.weldingdata.com/
Reply:A MM251 should have enough snot to do single-pass GMAW on schedule 40 pipe up to a 4 inch pipe or so.The machine should work fine for your smaller diameter pipe (turn the machine down a bit from all-out-nuke).MIG or TIG with the appropriate machine, either would work.  If you have a MIG machine, then you'll MIG it.  The best laid schemes ... Gang oft agley ...
Reply:i have a dynasty 200 dx and was cert. for sch. 40 stainless tigthat was almost 10 years ago
Reply:If those were my machines, I'd use the MM251 if in the shop on clean steel.  If this is field work, I'd probably Stick weld it with the Dynasty.
GMT+8, 2025-12-20 14:13 , Processed in 0.279589 second(s), 18 queries .
