E6010
发表于 2021-9-1 00:49:28 | 显示全部楼层 |阅读模式
does anybody have any tips welding with 6010? I can do stright stringers, padding, but when it comes to welding 6010 vertical i cant get the hang of it, or my weld looks like crap any kinda tips will help
Reply:Originally Posted by SICBOYdoes anybody have any tips welding with 6010? I can do stright stringers, padding, but when it comes to welding 6010 vertical i cant get the hang of it, or my weld looks like crap any kinda tips will help
Reply:Practice at other angles.  As the angle increases, you see what the puddle wants to do and what you have to do accordingly.
Reply:i found that for myself a u shaped pattern works good for vertical. just be sure to hold on the edge for a hair to keep from under cutting.  and with a slight angle to keep the tip pointed up. you just need to practice and find a pattern that you like.
Reply:Actually 6010 or 11 is about the easiest type of rod to run vertically.  Just taking a wild a$$ guess from what i see a lot of people do is that they put too much up angle in the rod. You talking about running vertically up, right?
Reply:try running some 1109 first. :-) people need to quit asking questions like this before searching the forums. This question has been answered 1000 times on here. --Gol'
Reply:Searching for the numerals 6010, I found threads having to do with everything under the sun! This one was a good thread though, I thought. http://weldingweb.com/vbb/showthread.php...highlight=6010City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I could only get that 1109 to run overhead.
Reply:E6010 electrodes are cellulosic and primarily designed for positional work vertical down.Cheers
Reply:6010 is one of the few rods allowed to go vertical down. It will weld either way. One who hasn't mastered vertical up shouldn't be trying vertical down in my opinion. But then my opinion means nothing.
Reply:Originally Posted by tresi6010 is one of the few rods allowed to go vertical down. It will weld either way. One who hasn't mastered vertical up shouldn't be trying vertical down in my opinion. But then my opinion means nothing.
GMT+8, 2025-12-20 14:07 , Processed in 0.084769 second(s), 18 queries .
