fabricating handrail question
发表于 2021-9-1 00:49:27 | 显示全部楼层 |阅读模式
Hi,I am new to this forum I am trying to build a handrail I have seen it done once and from what i understood from it was this i get the measurement of the platform on top and i need a measure ment from the top step  to the bottom floor(i want the rail to go into the floor) and a measure ment from the top of the platform to the end of steps(horizontal measurement) and i just plug that into the diagram?is this correct? what tools do u use to measure this the person i saw doing it just used a measuring tape and bent it to sort of a 90 deg but there has to be a more precise way?any help would be appreciated.
Reply:I posted this a few years ago.  http://weldingweb.com/vbb/showthread.php?t=5151You haven't provided enough information for the calculation of the lentgh of the rail.  I would do it by laying out a piece of metal across the steps and cutting it to length, then use it as a pattern. A problem you will run into if you build the rails as drawn is the front post on the platform will not have a place to be mounted.A few other members have also posted helpful techniques for building railing.  Do a search.Good luckLast edited by tapwelder; 10-09-2008 at 07:38 PM.
Reply:This might helpSTAIR, GUARDRAIL AND HANDRAIL INFORMATIONSTAIR REQUIREMENTSResidential (Single Family) Commercial (includes apartments)6' 8" headroom 6' 8" headroom7 ¾" maximum rise 7" minimum rise4” minimum rise 4" minimum rise10" minimum run (nosing to nosing) 11" minimum run (nosing to nosing)The greatest riser height within a flight of stairs shall not exceed thesmallest by more than 3/8".The length of landings shall not be less than the width of the stairway.GUARDRAIL REQUIREMENTSResidential (Single Family) Commercial (including apartments)36" minimum height 42" minimum heightMaximum spacing 4" Maximum spacing 4"Maximum 4 3/8 inch spacing at stairs Maximum 4 3/8 inch spacing at stairsLANDINGSRESIDENTIAL: (Single Family)• Stairs shall have a ¾” to 1 ½ “ nosing unless the tread depth is a minimum of 11”• A door may open at the top step on an interior flight of stairs, provided the doordoes not swing over the stair.• A door may open at a landing that is not more than 7 1/2 inches lower that the floorlevel provided the door does not swing over the landing. Screen doors and stormdoors may swing over stairs, steps or landings.COMMERCIAL: (Includes Apartments)• The length of landings shall not be less than the width of the stair but need notexceed 44 inches on a straight run.• There shall be a landing at the top and bottom of each stair. The landing shall be amaximum of 1 inch form lower than the threshold of a door (1/2" providing handicapaccess).HANDRAIL REQUIRMENTS• Handrails shall be 34 to 38 inches above nosing of treads.• At least one handrail shall extend 12 inches beyond the top and bottom risers.(Exception private stairways need not have extensions)• Handrails shall terminate in newel posts or safety terminals.• Handrails shall be continuous• Handrails shall be provided on all stairs having 4 or more risers.• Private residential stairways may have a handrail on only one side.• Handrails projecting from a wall shall have a space of not less than 1 inch nor more than2 inches in cross-sectional dimension and shall have a smooth surface with no sharp corners. Attached Imagesstait rail fab guide.pdf (105.3 KB, 120 views)Dan G. Rail.pdf (92.3 KB, 84 views)Last edited by Fat Bastard; 10-09-2008 at 08:19 PM.
Reply:There's 'a little more' to designing, fabbing and installing railings than meets the eye.        Kudos to Fat Bastard & Tapwelder!  Other items one may wish to consider is placement of the foot mounting plates--so they don't serveas trip points for people's feet. Attachment and edge distance for the foot plate mounts (especially if anchored into concrete.)  Location of the mount plate holes for drilling and fastener installation.Strength of the railing assembly and attachment system.    Any measured drainage slope, out of square/parallel, flatness of the mounting surfaces, needs tobe checked; etc., etc., etc.Blackbird
GMT+8, 2025-12-20 13:59 , Processed in 0.301956 second(s), 19 queries .
