LN 25 setup for CC
发表于 2021-9-1 00:49:26 | 显示全部楼层 |阅读模式
I have and old lincoln 225 with single cylinder 16 HP non CV.  Where should I set the output current for the LN. I have been setting on Max and fine on 3 or more but the .O68 211 MP still seems to burn hot . beads are smooth and uniformly rippled but do not seem to be shiny like a 7018 after its chipped.. I would like to tone it down for welding 12 ga and above and more in the range of 3/16 and 1/4. Also it burns so hot I have to move rignt along. I would like to slow the travel down and be able to fill semi poor fit up."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Go ahead turn it down.  I would have one hell of a time welding thin stuff without CV.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 14:13 , Processed in 0.096494 second(s), 18 queries .
