Homemade seat
发表于 2021-9-1 00:49:24 | 显示全部楼层 |阅读模式
Anyone ever weld together any seats for their golf carts?  I am about to weld some bed rails together for a frame to hold my seat on my golf cart.  If anyone has any suggestions I sure would appreciate them.Thanks Calvin
Reply:I've welded up bracket to adapt bucket seats into a car but never a golf cart. Can you post some pics, it may help generate ideas.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I've welded up a seat bracket or twoEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Calvinjeep89Anyone ever weld together any seats for their golf carts?  I am about to weld some bed rails together for a frame to hold my seat on my golf cart.  If anyone has any suggestions I sure would appreciate them.Thanks Calvin
Reply:Broccoli, what is that cart for?  Never seen anything like it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammBroccoli, what is that cart for?  Never seen anything like it.
Reply:Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That would fit nicely at Burningman.  I've seen some of the pics on the net.  Lot of really cool stuff done out in the desert.Didn't someone start the fire early this year?I'd like to go there some day.Oh, and hey?  The lady that takes care of my mother dropped off a bedframe that she wants welded in order to firm up the brackets that hold the headboard, and footboard.  I didn't realize these things were made out of spring steel.  Anything I should do different when welding it?  I was just gonna use the wire welder with flux core."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I imagine it will be fine-Certainly the heat will change the temper-but how much and does it even matter in this situation?I don't think it will cause the steel to become so weak as to worry about failure- but dunno this gal- maybe she is quite activeEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:She's a pretty good sized ladyShe's in her mid fifties, and has a heart of gold.  Hired her to come in and look after Mom in the other house.Thanks for the heads up on the bedframe.  I got worried for a second."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-20 14:22 , Processed in 0.064816 second(s), 18 queries .
