BI pipe
发表于 2021-9-1 00:49:16 | 显示全部楼层 |阅读模式
what is BI pipe ?do the B & I stand for something?Talent is a flame. Genius is a fire.- Bern Williams
Reply:Do you mean "black iron" pipe?  I usually see it used for plumbing, mostly nat. gas.  Other than that, I don't know much about it.  Somebody will.There's also a difference in fittings (elbows, nipples, etc.).  Cast fittings won't take high pressure, and forged ones will take high pressure like hydraulics."Any day above ground is a good day"http://www.farmersamm.com/
Reply:It stands for "black iron" to me. Common steel pipe that lumber yards and a lot of suppliers sell. In the oil field it is usually just called "black pipe" to destinguish it from other types of pipe.
Reply:thank you kindly fellasTalent is a flame. Genius is a fire.- Bern Williams
Reply:http://www.steel-pipes-tubes.com/ind...pes-tubes.htmlEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-20 16:09 , Processed in 0.088820 second(s), 18 queries .
