What rod/filler material to use to join 316L and Monel?
发表于 2021-9-1 00:49:15 | 显示全部楼层 |阅读模式
What rod/filler material to use to join 316L and Monel?Have tried 309 filler but sometimes get cracking.  Any other filler material recommendations?Thank you,BennyB
Reply:You will probably need something with a much higher Nickel content. I have used NiCrFe-3 in the past . Of course service conditions etc may dictate a better choice,Have a nice dayhttp://www.weldingdata.com/
Reply:You can get a good weld with no cracking issues using Hastelloy.Regards, KbnitI r 2 a perfessional
GMT+8, 2025-12-20 16:09 , Processed in 0.095794 second(s), 18 queries .
