Flux core mig welding
发表于 2021-9-1 00:49:07 | 显示全部楼层 |阅读模式
Using flux core mig welding wire,  which size would give better penetration .030 or .035?This would be on mild steel at 1/4 inch thickness.Thanks,Jack
Reply:What machine are running it on?The .035 would be able to carry more current, if your machine can back it up.Yup
Reply:The machine is a Century 200.  I think max current is 160 amps.
Reply:the E71T.035 should fit the bill fine.. Usually its a little bit cheaper than the .030, and should flow nicely.. I have a chart at the office that is broken up into columns showing amperage, material thickenss, and wire size / suggested speed. I will post it if I can get it scanned in tomorrow..Carl
Reply:Thanks in advance for such a chart!By the way, I did not know they made E71T-1 in 0.030
Reply:Can someone tell me how to upload it? I will post those charts.. Thanks.Carl
Reply:I also found those charts on the back of 10lb boxes of Hobart wire.
GMT+8, 2025-12-20 14:38 , Processed in 0.209332 second(s), 18 queries .
