question about AC-DC welding machines
发表于 2021-9-1 00:49:06 | 显示全部楼层 |阅读模式
the ac-dc welding machine has 2 outlets ac and dc ,normaly we use either the dc or the ac outlet , the question is can I use both outlets at the same time ,(because if so without harming the machine,this will save me buying another machine)
Reply:Nope. Wont work. The AC is just the DC straightened out. Better start shopping.
Reply:What machine is this, and are you talking about 110V outlets, or welding power outputs?
Reply:From the sounds of it, i'd venture a guess he's talking welding outlets.  and No... not at the same time you can't use them.One or the other, but not both.
Reply:Sounds like a shop environment setup.  NOPE.  Can't use both at same time.  Get another machine.If you do plan to try it, will you get a video of the results and post it here?
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-20 14:38 , Processed in 0.068716 second(s), 18 queries .
