New Toys & Project On the Fun Side...
发表于 2021-9-1 00:48:50 | 显示全部楼层 |阅读模式
Hi...  I was wondering if anyone that works with Carbon Arc Torches, or their related carbon electrodes has ever tried to make one of the following...  A Yablochkov candle (sometimes electric candle) is a type of electric carbon arc lamp, invented in 1876 by Pavel Yablochkov.It consisted of a sandwich of two long carbon blocks, approximately 6 by 12 millimetres in cross-section, separated by a block of inert material such as plaster of paris or kaolin. There was a small piece of fuse wire or carbon paste linking the two carbon blocks at the top end. The assembly was mounted vertically into a suitable insulated holder.On application of the electric supply, the fuse wire 'blew' and struck the arc. The arc would then continue to burn, gradually consuming the carbon electrodes (and the intervening plaster) as it did so. The first candles were powered by an alternating current Gramme machine.On disconnecting the supply, the arc would extinguish. It could not be restarted as there was now no circuit between the electrodes. It was necessary to replace the candle with a new one.The advantage of the design was that it removed the need for any mechanical apparatus, a regulator, to maintain the needed distance between the carbon blocks to sustain the arc. Electrodes would last about two hours.It was first demonstrated, as street and theatre illumination, during the Paris Exhibition of 1878, notably on the Avenue de l'Opéra. The candles were enclosed in globes of enamelled glass, with four to twelve candles in each connected in series  Let me know if anyone figures out the distance between the electrodes, and a good insulator that might be in a junkpile somewhere.  Thanks,   Ed VA  "It's only impossible when you prove to yourself that it's impossible."
Reply:I have seen some interesting stuff lately with carbon arc rods.  I think the HHO/ fuel cell crowd has bought them all up.Watch this:Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Says the video is no longer available.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duaneb55...  I believe the "speed of dark" is just fast enough to keep out of the way of light... 186,000 MPS.  Sounds logical to me !  He-heEd VA"It's impossible only when you prove to yourself that it's impossible."Clarke 95ELincoln 225/125 AC/DC& Enough stuff to keep my wife p'd-off !AND A "Fertile Imagination" which I've been told it's because I have crap for brains.  (Lots of Fertilizer up there !)Last edited by edv7028; 11-22-2008 at 01:35 PM.
Reply:Well it is still available. Maybe I didn't do something right.  Go to you tube type in: hho carbon arc and have fun.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-20 15:49 , Processed in 0.095251 second(s), 18 queries .
