查看: 13|回复: 0
Dozer Undercarriage Build Up
发表于 2021-9-1 00:48:47 | 显示全部楼层 |阅读模式
I have a John Deere 350B with a mostly wore out undercarriage. I don’t put many hours a year (50-150) on it and can’t justify the bucks to replace the bottom right now. I thought I might give building up the components a try. Any  tips on building up the rails aka chains and the track rollers and idlers? I plan to use stick and my SA200.Do you machine it post weld or just try to get it reasonably smooth and let it wear in?
Reply:I have done a couple.  Both were with a mig, .045 wire and co2.  Its fun at first,but gets boring.....I never built up a set of chains.  I have cut the sprockets off a cat D6 and welded new ones on.I did the rolls in a cut down 55 gal barrel with some water in it.  Weld a little, roll it in the water.  The rolls don't have to be taken apart.  Just make sure they are full of grease when done.  After a while you will be able to lay it down pretty flat.I did the idlers right on the machine.  I tacked a couple of tabs on the side for the ground.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I work for a deere construction dealer  and would recomend not  welding  the lower rollersas they have seals and are oil filled  are the chains sealed  or dry bushings    another option is used or aftermarket  parts  hope this helps hypertherm powermax 900 : miller 30a spoolgun ranger 305g lincoln ln-25more tools than a tool truck
Reply:Originally Posted by rookiewelderI work for a deere construction dealer  and would recomend not  welding  the lower rollersas they have seals and are oil filled  are the chains sealed  or dry bushings    another option is used or aftermarket  parts  hope this helps
Reply:its usualy cheaper for us and quicker turn around for the customer  to swap parts  if it were mine you had some good ideas david i might go that route  I have more time than money hypertherm powermax 900 : miller 30a spoolgun ranger 305g lincoln ln-25more tools than a tool truck
Reply:Do you need to re-establish base material, or apply a wear resistant lining ? I assume both and this can be done, however some parts, eg: rollers, need total strip down, welding, machining and reassembly.Building up chains used for load is not recommended, however in a wear application, again possible provided done correctly.Rebuilding and hardfacing track pads is very time consuming, however rebuilding and hardfacing wear parts is cost effective, and if done correctly may outlast new replacement equipment. needless to say, this work is in the realm of professionals and must be performed correctly to ensure servicability and avoid failure / cause injury.If you provide base material details for all the parts, I may be able to provide some welding guidelines.
Reply:How is that cross bar on that 350, I have fixed a couple of them now where the bolts have come loose and they have been run, oblonging the holes."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I believe the JD has greasable rollers.  Just watch the seals.One thing, that you can't build up very well are the pins and bushings.  Those must be turned or replaced.  Poor condition of these is one of the major causes of wear to the rest of the undercarriage.The cleats, the idlers and even the sprockets may be built up, but be sure the sprockets aren't left with a point on the end.  I have built up these parts with hardfacing rods, and nickel based rods, but nothing beats a new pair of shoes for the tired feet.Berco may actually have reasonable priced replacements for the undercarriage where things aren't fixable.  Go here:  http://www.bercoamerica.com/Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Be glad it ain't a Komatsu 575, worlds largest dozer.  To replace the undercarriage, it's $250,000.At our local Komatsu dealer, they have an automatic welding setup to reweld undercarriage componenta.  Submerged arc, the works.  Pretty neat operation.Good Luck with your rebuild.
Reply:Hey Rookie welder, Nice deer that you and you boy got!  You will have to give me call and give me more details!  A friend of mine got a real nice buck with a big rack tonight!  I could not see if it was a Mule or a White Tail, as it was along the side of the road.  The only problem was that he got it with his Mazda pickup!    Probably totaled it out!  Here is what I have so Far:Miller:Shop Master 300 A A/C D/CS 22a Wire FeederRFC-14 Tig PedalHF-251D High Freq. UnitProfax 250 A Mig GunVictor RegulatorsHarris:63-2 torch Cutting Attachment 49-3making home built tig cooler
GMT+8, 2025-12-20 19:58 , Processed in 0.091181 second(s), 18 queries .
