Will this tig torch work?
发表于 2021-9-1 00:48:46 | 显示全部楼层 |阅读模式
Does anyone know if this tig torch would happen to fit the harbor freight 80 amp inverter. Im assuming the terminal on this is probably the same size as the one on the harbor freight. Heres the link. Don't worry im not paying 100 for it i found one super cheap on ebay. I just would like to know if it fits the harbor freight. ThanksShanehttp://www.chpower.com/webapp/wcs/st...1_10681_10761_
Reply:The main issue would be the design of the torch power lead connectors - DINS, Tweco, or proprietary design.  You could contact CH customer support and ask if it is a standard design, and if so, which one.  I own some CH equipment and they have been very good about warranty work - replaced blown diaphragm in a regulator no hassle.  Then contact HF and ask the same questions about the female connection of the power supply.  You may end up having to buy a replacement HF male to install it on the CH torch lead.   Do you plan to hook up the torch gas connection directly to the low side of a regulator?TeddCoHTP Microcut 400 & Invertig 160DC  Smith Dual Guard MD-510 OA Rig  Lincoln SP135+  Hobart Stickmate LX 235/160
Reply:Yea i just sent ch a message. All i really need is the measure of the terminal from the tig torch. Theres a deal with one on ebay, but i might just be better buying a 2 piece torch name brand that i could use later on too.
GMT+8, 2025-12-20 15:49 , Processed in 0.107088 second(s), 18 queries .
