Carburetor #s for 225 linc welder
发表于 2021-9-1 00:48:44 | 显示全部楼层 |阅读模式
I have a lincoln 225 linc welder  model dc-225-/3-AS code # 8572  serial # A 1029816. According to lincoln it is about a 1984 it has a onan ccka engine in it. I have lost the tag off of the carb and need some parts for it. The carb is a zenith facet vd, if someone has a machine like this would you look at your tag and send #s     THANKS
Reply:Does this help?http://www.autotestsys.com/Merchant2...egory_Code=ZENMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:No, but thanks  did not see my model on chart. Need to know vd # (ex) vd63 vd 65 vd 84 with vd # can cross to onan part# THANKS  I can use this chart on other engines
Reply:Sorry it didn't help.  I used to work on those Onans all the time and probably still have some small parts for those carbs in my 'left-overs'.I'll keep looking.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Maybe this guy can help.http://cgi.ebay.com/CARBURETOR-CCK-C...029105004r3910MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:There's a WeldingWeb member who's screen name (and probably website) is: "onanparts.com"You might raise him with a PM.Good Luck
Reply:Thanks denrep & duaneb55 for your help. I e-mailed onanparts.com and he sent me a parts manual and he can get the parts i need  THANKS AGAIN
GMT+8, 2025-12-20 15:49 , Processed in 0.100218 second(s), 18 queries .
