I recently baught a little Lincoln AC/DC 225/125 welder. It worked fine when I welded with it when I bought it but here at home only the fan runs, no spark at the work end. I oened the unit up to see if there was any loose connections but did not see any thing . Any idea's or input would help alot. thanksLast edited by R Lloyd; 12-08-2008 at 05:24 AM.
Reply:Do you have the ground clamp properly attached to your workpiece?
Reply:Check your plug and or receptical, sounds like you only have 110 volts going into the machine. Also check your ground as was already suggested.I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation! |
