Anyone use their tig for making small bends? Find it does a nice job, Use a blut tip and Keep the heat low enough to prevent making a puddle. Quite a bit of heat control, but can only manage small pieces. Torch is likely better, but TIG is quick if you are already welding.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
Reply:Makes sense; a tig torch is exactly that; a torch. it just uses electricity instead of combustible gas as a heat source. Maybe a bit too focused, but that just means more practice!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return. |
