3G welding test
发表于 2021-9-1 00:48:32 | 显示全部楼层 |阅读模式
can someone put a pic of a 3g test. i don't know how its supost to look when its done
Reply:http://www.tpub.com/content/construc...14250_55_1.jpgi always thought there was a 3G but cant find any info other then these
Reply:i always thought 3g was horizontal
Reply:3G vertical UP, 3/8" 4" X 6" plate 22.5* bevel on each one for a total of 45*  1/8 to 1/4" root gap, 1/4" X1" backer 8" long  I took it with .045 wire and Co2.It should look like you did it flat pretty much.  Up to 1/8" proud.  3 passes, I turned the welder down for each pass.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I think 2g is the hardest
Reply:Heck, even my phone can do 3G...
GMT+8, 2025-12-20 15:50 , Processed in 0.094611 second(s), 18 queries .
