Difference between AC & DC welding performance?
发表于 2021-9-1 00:48:25 | 显示全部楼层 |阅读模式
Hi there,I'm just a hobbiest, but using arc welding for several years now. Though I can't still weld as excellent as the pros, but doing average in most of my projects at home.I just want to know more on the difference between welding in AC & DC mode? I had been using an old Miller Thunderbolt 225 CC-AC Welding Power Source which has only Arc AC source, though I got it brandnew during that time.Can someone help me evaluate this issue? before I get a unit with DC mode machine?Regards,5Zero
Reply:Here's a thread that's only a week old:http://weldingweb.com/vbb/showthread.php...ghlight=versus
Reply:I just turned the corner to DC.  Been runnin' AC for over a decade.  I'm really likin' it.I don't intend to abandon the AC side of my machine though.  I can run bigger than 1/8 rods on AC.  I have a motor drive machine, but I don' t even dream of runnin' it for the bulk of the work I do.  It's too damn expensive to run.  Lot cheaper to run on the grid.If you're like me.  A Lincoln 225AC/125DC or the comparable Miller machine will serve you well.  Don't let folks push ya into a machine that's more than you need.  Sure it's nice, but how many times are you actually gonna benifit from the added goodies."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-20 15:51 , Processed in 0.068075 second(s), 18 queries .
