drill pipe
发表于 2021-9-1 00:48:19 | 显示全部楼层 |阅读模式
New here, needing help has anyone welded tool joints on drill pipe? I traded for some pipe and it is 30' joints i need 20' joints. Maybe cut 10' out weld it  and brace it someway and use weld on tool joints on the 10' thats left. Thanks konk.
Reply:Originally Posted by konkNew here, needing help has anyone welded tool joints on drill pipe? I traded for some pipe and it is 30' joints i need 20' joints. Maybe cut 10' out weld it  and brace it someway and use weld on tool joints on the 10' thats left. Thanks konk.
Reply:bdeditch Thanks for the reply. I'm drilling water wells 300' to500' sand, shale,limestone, sandrock. They make weld on tool joint i have never used them. I was hopeing someone had and could tell me pros & cons or what they have seen done. I  see your in the oil field and understand why you just replace. Thanks Konk
Reply:I dont know what kind of drill pipe and threads you got. But here in Boise there is a company called Drill Pro that makes drill rod, subs, and collars for me. They might be able to help you out with advice, at least if they think you might buy something from them, they can be asses if there busy though. Their number is 208-336-4970
GMT+8, 2025-12-20 15:49 , Processed in 0.214604 second(s), 18 queries .
