I've been looking for some hexagonal tube about 1" OD in small quantities, either in aluminum or steel. Does anyone have a source? ThanksAllen
Reply:http://www.plymouth.com/shapedtube.aspxhttp://www.jackson-tube.com/shapeHexagonal.htmmetrichttp://www.nordicaluminium.fi/linked...iilit_e_18.pdf www.freedom-steeltubes.com ( my firewall is kicking this one as a bad site) i would try to call them or look at the google cached pagesLast edited by chenry; 01-20-2009 at 05:19 PM.insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Depending on how small, check McMaster Carr, too.
Reply:Fastenal has it...although their prices can be higher, you get what you need.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks guys, the "small quantity" part has been the problem with getting it from manufactures.McMasters only has very small diameters. I couldnt find anything on Fastenal's website, I'll have to give them a shout on the phone.AllenLast edited by minner; 01-22-2009 at 08:17 AM. |
