Dialarc welding leads
发表于 2021-9-1 00:47:58 | 显示全部楼层 |阅读模式
Will a 75 foot #1 wire be heavy enough to use on a dialarc welder.5/32 would be max size rods and probably nowhere near the duty cycle most of the time??
Reply:It appears you posed the same question, several hours ago, on link below:http://www.practicalmachinist.com/vb...d.php?t=173571How much amperage will you be pushing with these unknown rods?Did you Google welding cable ampacity or search on this site for welding cable sizes?.....or are we supposed to do that for you as well?Blackbird
Reply:7018 at 130 or so.yes i checked them out  but i prefer real world input ,somehow things are always different in the real world.Chill out bird i aint your wife
Reply:From my Dialarc HF owner's manual-Cable length up to 150' round trip, 75' each way +/-Current up to 200 ampsDuty cycle 60% to 100%Use # 1 cableFor up to 150 amps, use # 2 cableMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 15:53 , Processed in 0.069878 second(s), 18 queries .
