miller aed 225 onan engine swap
发表于 2021-9-1 00:47:56 | 显示全部楼层 |阅读模式
Anybody know of another motor to swap out the onan with?  I've got the welder sitting here, with a blown motor.  We checked on a rebuild kit, it was priced at around 1500 bucks, and I've seen these welders complete on craigslist for around 800.  Just weighing my options.  thanks
Reply:sorry, looks like I posted this in the wrong forum
Reply:wrong model number too, its an aead 200 le
Reply:Don't know where you got your parts prices but before you give up on the Onan, check here http://onanparts.com/.  He's a member here too if I remember correctly.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Also, there are usually guys partsing a motor on eBay.Search for "b48m".  That's the engine in an aead-200le.If you need the engine repair manual, send me a PM.  I've got a PDF.
Reply:just sent you a pm rlitman.  I will look again for parts.  napa quoted my dad that 1500 bucks for the rebuild kit.  I just picked up another one of these machines, an AEA 200 Le.  Its older than the one with the blown motor, but seems to weld fine.  I'd still like to get the other one going though.  Thanks guys.
Reply:You can pick up new Kohlers on line in the 18-20 hp line with a tapered shaft for less than that sometimes.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-20 15:53 , Processed in 0.091318 second(s), 18 queries .
