Miller diversion 165
发表于 2021-9-1 00:47:52 | 显示全部楼层 |阅读模式
I ve been looking for a decent priced ac/dc tig welder.  I found a brand new diversion 165 online for about 1200.00 bucks.  Anybody got any experience with this welder?  I wanna get my feet wet with some aloooooooooooominum  welding.  Is this welder the ticket?..............Thanks for the help RichLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:I will be watching this! Lincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:I have had a Diversion since October. It suits my hobby needs perfectly. I've found that it welds aluminum quite well, but keep in mind that I am the opposite of an expert!
Reply:I have never used that machine.  How thick aloominum are you planning on welding?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I used one at miller, great little welder. Its about exactly what a Tig welder should be for a guy wanting to fabricate from about 1/4" and under. Its probably really at home doing 3/16 and under though, but with pre-heating even castings should be doable.
Reply:does anybody know if you can stick weld with it?Lincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Originally Posted by David RI have never used that machine.  How thick aloominum are you planning on welding?David
Reply:Originally Posted by rwells173probably nothing over 1/4 inch.  Why do all you guys spell alooooomeeeeum funny?
Reply:Nope no stick welding, its got a factory attached torch.
Reply:Originally Posted by rwells173does anybody know if you can stick weld with it?
Reply:Originally Posted by David RI did because you did!I think the duty cycle on that machine at 160 amps is 20% which isn't much.  I have a TA185 and it takes ALL its got to weld 1/4" 2X2 angle.  That is why I asked.David
Reply:Originally Posted by makoman1860Nope no stick welding, its got a factory attached torch.
Reply:I think it will do what you want.  What about a used econotig?David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:be careful on how thick of aluminum you want to weld with the diversion.  The new weldcaraft torch that is wired in is only good for 100 amps AC and is not interchangeable on that welder.  It is also a pretty big ticket torch because the controls are integral to the handle.2 Trailblazer 302's2 HF251-D1'sDynasty 200DXLincoln Powermig 140CHypertherm Powermax 30Airco Torches out the a$$
Reply:David, is it an inverter?  how many amps? how much? where am I? how come I keep hearing voices?Lincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Originally Posted by cryowelderbe careful on how thick of aluminum you want to weld with the diversion.  The new weldcaraft torch that is wired in is only good for 100 amps AC and is not interchangeable on that welder.  It is also a pretty big ticket torch because the controls are integral to the handle.
Reply:I have one and am happy with it.  The majority of the aluminum I weld is .125 and it does a fine job for what I need.edited to add that I bought a pedal for it.Last edited by mjb; 02-02-2009 at 08:50 PM.
Reply:Originally Posted by mjbI have one and am happy with it.  The majority of the aluminum I weld is .125 and it does a fine job for what I need.
Reply:Originally Posted by rwells173do you like the hand controls?
Reply:Originally Posted by mjbI can use it, but the pedal is way easier.  If I had never used a pedal before, I wouldn't have known the difference.
Reply:Yep,Perfect candidate for a Miller Diversion 165.Doesn't want to expend the effort to download the spec sheet and "read" the machine capabilities.Already has visions of using the machine for material it was never designed to do.Hasn't downloaded or requested a copy of Miller's 2009 catalog.  Clearly states that a foot pedal option (RFCS-RJ45 Foot Pedal #300 432) is available.Machine comes with a set-up and operation DVD.  That's great.  Won't even have to read the owners manual.  Also allows unlimited questions on the Miller welding forum.And, the final kicker, the machine comes complete with a book, "Tig Welding for Dummies with content by Miller".  With this exhaustive reference, no additional study of the tig process will be required.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by SundownIIIYep,Perfect candidate for a Miller Diversion 165.Doesn't want to expend the effort to download the spec sheet and "read" the machine capabilities.Already has visions of using the machine for material it was never designed to do.Hasn't downloaded or requested a copy of Miller's 2009 catalog.  Clearly states that a foot pedal option (RFCS-RJ45 Foot Pedal #300 432) is available.Machine comes with a set-up and operation DVD.  That's great.  Won't even have to read the owners manual.  Also allows unlimited questions on the Miller welding forum.And, the final kicker, the machine comes complete with a book, "Tig Welding for Dummies with content by Miller".  With this exhaustive reference, no additional study of the tig process will be required.
Reply:Originally Posted by rwells173David, is it an inverter?  how many amps? how much? where am I? how come I keep hearing voices?
Reply:Originally Posted by neat-oYes, it's an inverter.165 amps maximum. About $1200You're on the internets. You're off your meds again.
Reply:Now ya know why they call him   "SUNDOWN"  It should have been  "putdown"The other day I got a vaigra stuck in my windpipe!!Had a stiff neck for 32 hours.Lincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:Originally Posted by 1awert1Now ya know why they call him   "SUNDOWN"  It should have been  "putdown"
Reply:I think he was asking about the econotig. It is NOT an inverter, but it will stick weld.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I was David and thank youLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Originally Posted by rwells173Dam,  who pissed in your cornflakes?
Reply:Originally Posted by down19992000Thats all sundown is good for putdowns and insults.
GMT+8, 2025-12-20 15:52 , Processed in 0.070052 second(s), 18 queries .
