springs for brush holder/retainer
发表于 2021-9-1 00:47:49 | 显示全部楼层 |阅读模式
Need new spring for brush retainer on 1980 vintage Hobart G-213 2 cyl gas drive arc welder. Anyone know if these parts or brush kits are available? Where? Pictures attached. Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:The first place I would check is at a local motor re-wind shop.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Did you check with Hobart?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-20 19:59 , Processed in 0.118527 second(s), 19 queries .
