? gun for LN 25 ?? mig
发表于 2021-9-1 00:47:49 | 显示全部楼层 |阅读模式
I have the older model, not the pro.     I need to buy a gun to do dual shield w/.     Can I get some opinions on different guns and why ?     I have only the k126 innershild gun.
Reply:Weldingdepot.com sells nice knock off Tweeco guns and other brands.  Lincoln magnum guns are great.Be sure to get on to fit an LN-25.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:The Tweco Spray Master is a very nice gun for heavy dualshield use.They are real light, run cool under hard, high amperage use and the little manual trigger lock is slick.JTMcC
Reply:Sounds like tweco it is.    I'll have to go to that site and check on the Spraymaster.    The one I've used had a threaded two piece cup that went onto a diffuser w/ like allthread on outside for adjustment, I liked it, whatever it was.
Reply:That sounds like the frontend on my Spoolmatic/XR gun before I converted it to Centerfire.   On that one the barrel was threaded and the nozzle length was adjustable so the tip could be recessed, flush or sticking out by varying amounts by twisting the nozzle.   Sometimes it would twist by itself.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I have a magnum 300 on my circa '88 Ln-25. Got it at weldingsupply.com for less than the Tweco. Have a Tweco on a Hefty feeder as well (the Magnum is heavier built). The Tweco's are very good guns, and parts interchange between the Lincoln and Tweco and are easy to get. We have centerfires at work but are changing over to Tweco's.Last edited by Jolly Roger; 02-06-2009 at 10:14 PM.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Whatever you do don't get the Tweco Weldskil, I've had this gun on two different welders and I HATE it.  I'm swapping to a Bernard.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
GMT+8, 2025-12-20 16:12 , Processed in 0.070996 second(s), 18 queries .
