help, how to build adjustable speed bag platform
发表于 2021-9-1 00:47:48 | 显示全部楼层 |阅读模式
hello, i would like to be able to build an adjustable speed bag platform because the ones for sale cost way too much. ive been visiting a speed bag forum where alot of other people build there own platforms but usually they are wood, and any metal ones they build dont adjust, so i know there are others on that board who would appreciate any answers to my q's. i would like it to look like any of these http://www.combatsports.com/detailpo...AGES/mrsap.jpghttp://www.balazsboxing.com/cgi-bin/...ag%20platformsin the first link and the first pic of the second link....is there a special name that you would call steel tubing when it has that "sliding sleeve" around? is there any place i can buy a pre drilled rail (seems like it would be hard to get all the holes perfect on both sides) and a prewelded pop pin "sleeve"? ive searched for a couple days now and cant find anything online, the only thing i found out was the pins are called pop pins. also what would the remaining "slide mounts" on the second page be known as? thanks for nay help!!! Last edited by reellife; 02-07-2009 at 01:16 AM.
Reply:All you need is seamless tubing sized so they nest in eachother.  Local metal supplier should be able to provide that.  Measure and mark the hole locations carefully and drill them on a drill press, clamped in a vice mounted to the drill press table.   The pins may also be called hitch pins.  Or you could weld nuts centered over the holes and thread bolts into them, tighten bolts down to keep tube in place.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Hello and welcome to the forum.Another thought might be to use perferated angle iron. ( the sort of stuff you see garage door tracks and openers hung with frequently). Depo carries some and you can get heavier material at some suppliers.  You could mount 2 pieces on each side sort of like this  _|    |_    and put a "spacer" in between top and bottom to keep them seperated.  Mount the unit to a piece of square tube with holes drilled to match the perf angle.Another thought if you don't weld, post up where you are from. Maybe some one here is local and will give you a deal to help you out. With things the way they are now a days, lots of guys will take all the small side jobs I could get.
Reply:ah, it seems peforated was the magic word. ijust thought to try that shortly before you said it. i found "telescoping perforated" steel tubes for about $10. i actually dont have welding equipment, and was gonna ask the local high school to do it, as we used to do jobs for people wheni was in the class. but i live in grand forks north dakota, and go home to the bemiji minnesota area alot. so if anyone is around either of those areas and would consider building this http://www.balazsboxing.com/cgi-bin/catalog2.cgi?action=page&page=gear|speed%20bag%20p  latforms|ms0057 let me know how much you would charge. a plate welded to the arm would be best for attaching the board. if anyone is interesed, please let me know seperate pricing for the adjustable arm and the two wall brackets, as i could use boards if the price savings was worh it. thanks for the help guys!
Reply:http://www.alliedtube.com/sign-suppo...par-square.aspShould be able to get this stuff at the local steel supplier. HD may even have some.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-20 16:14 , Processed in 0.128210 second(s), 19 queries .
