Welder/Fitter
发表于 2021-9-1 00:47:47 | 显示全部楼层 |阅读模式
Hi all,What is a Welder/Fitter?  I think I can figure out the welder part but does fitter refer to pipefitting?Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:I think it's an HR geek who fits a welder to a jobA butterfly without wings, is just an ugly bug
Reply:Originally Posted by NiteskyHi all,What is a Welder/Fitter?  I think I can figure out the welder part but does fitter refer to pipefitting?
Reply:A welder/fitter is a welder who does his own layout and fitting be it pipe, plate or structural shapes. They are also referred to as singlehand welders in some areas.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Thanks for the information.  You won't ever know if you don't ask for Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
GMT+8, 2025-12-20 16:10 , Processed in 0.091558 second(s), 18 queries .
