wear alloy 400
发表于 2021-9-1 00:47:34 | 显示全部楼层 |阅读模式
im putting a new bottom in a cat 972g loader bucket. welds seem to cracking on cutting edge side of plate. i read on this site about pre and post heat. how hot? customer supplied plate
Reply:Is the bottom plate is AR400?  How thick is it?  This will affect how much pre-heat and interpass temperature that needs to be maintained.What filler metal and process are you using to weld the plate?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:as it would turn out. i think i figured it out. to answer ur ? though, i arc aired the old plate out. new plate 3/8". cutting edge 1 1/2". L56   045 mig tri mix gas. appreciate the concern!
GMT+8, 2025-12-20 16:09 , Processed in 0.093983 second(s), 18 queries .
