Flat Bar
发表于 2021-9-1 00:47:28 | 显示全部楼层 |阅读模式
A customer called and told me that the local mill used to make a flat bar that measured 1" x 1/4" with a side bevel that met in the middle.  Almost in a diamond shape.  Anyone ever heard of this stuff before?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Kind of like a grouser bar?
Reply:Don't think it would be a grouser bar as the smallest grousers are 1 1/8 x 1/2 with bevels. This would be Duratuff anyways. But I agree it does sound like thats what it should be. Did they say what they wanted it for?
Reply:I have seen and used it. I think it was cold rolled steel. I was a welder under contract to help out a concrete company repair some molds for some of the pre-cast products. We had a great deal of this. It was used in the corners of the mold to give the finished product a relieved edge, (like beveling an edge of wood or steel) This edge treatment kept the finished concrete from having a square, easy to break edge. I have never seen it anywhere else, but if you are looking for it, you might find someone who does pre-cast work, check out his suppliers or catalogs.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:I found out it is called bar grate.  Mostly used as fireplace grates.  Now I just have to find a local supply of them. They used to roll them at the mill the same way you do flat bar.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-20 16:10 , Processed in 0.068765 second(s), 18 queries .
