what's best mig welding wire to weld stainless steel?
发表于 2021-9-1 00:47:26 | 显示全部楼层 |阅读模式
I also want to know which brand, thickness and the best gas mixture. I'll appreciate your opinions. Thanks!Midwest Metal ProductsMetal Wire Forming Fan Guards Delta-Larm
Reply:We use a ton of sandvik 308Lsi. .035 tri-mix gas it runs real nice
Reply:Originally Posted by mrandreiI also want to know which brand, thickness and the best gas mixture. I'll appreciate your opinions. Thanks!
Reply:what kind of SS, and the size? 98Ar+2O2 mixed gas would be OK for lot's of SS.maybe TIG is suitable 2(100Ar)Last edited by xixiubin; 02-25-2009 at 10:04 AM.Just call me Robin
Reply:As said, ...the brand - usually a 'name' brandthe "thickness" - the appropriate "thickness" (did you mean the wire diameter? )the gas - the appropriate gas for the wire type and size and transfer-type and material thicknessYou're not really going to want to use 0.045 diameter wire in spray mode with 98-2 argon-O2 working on 20 gauge 316 stainless out of position.  Unless maybe it's pulsed spray. And you're not going to want to use C25 and 0.030 308 wire for thick multipass welds on 316 material.Etc, etc, etc.Use the appropriate wire diameter and type and the appropriate gas and the appropriate transfer mode for the job.  The best laid schemes ... Gang oft agley ...
GMT+8, 2025-12-20 16:10 , Processed in 0.108563 second(s), 18 queries .
