SA 200 Polarity switching for stick or LN25
发表于 2021-9-1 00:47:22 | 显示全部楼层 |阅读模式
Okay, My father used to switch polarity or the cables around on our SA200 when he was doing certain jobs with rod and when he was using his LN25. I dont remember why, and Im sure he told me many times but I wasnt the one welding at that time. Could anyone out there tell me WHY? and which way to have them for running the LN25?? The LN25 is running flux-core wire, if that matters.  I remember he did it for overheads, or veriticles too... I just dont remember clearly WHY or when  or which way for which applications. Any help would be appreciated. Thankyou.The first step to having everything you want is to want everything you have.
Reply:Self shielding flux-core wires are run reverse polarity. DCEN, I am asumeing you are running somthing like NR-211 or NR-232.
Reply:mig (solid wire and shielding gas)- run electrode postitveflux cored wire- run electrode negativestick- run electrode positive, most of the timeMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 17:20 , Processed in 0.109289 second(s), 18 queries .
