Does anyone ever seen one of these?
发表于 2021-9-1 00:47:21 | 显示全部楼层 |阅读模式
Its a Gilliland machine that was used at a shipyard. The guy who gave it to me only knew that. I have contacted manufacturer with no luck, and asked around San Diego and struck out there too. I have no clue on how to hook it up or what it takes to do that. Here are some pictures, any help/info would be greatly appreciated. Attached Images
Reply:I am sure you have seen the website. It looks like an older model...Bobhttp://216.135.251.82/gillilandweave...tgilliland.htmBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Holy Crap!Can you say "Not for autobody work".....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks like it could make your lunch.   Do you have a power supply for it?Whatabeast!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:What power supply would I need? I'm totally lost with this.
Reply:David R, could a Miller XMT 304 work for power supply?
Reply:For all the complexity of the knobs and flippy switches...it looks like a cv/cc voltage sensing wire feeder.  The three plugs for the electrodes has me stumped.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboy The three plugs for the electrodes has me stumped.
Reply:It is a industrial wire feed welding machine.It is CC/CV it can TIG, MIG and Stick weld (SMAW). The 3 electrode ports are labeled, A B & C and it would be quite easy to find out if one of those ports is a ground.Without the remote cables and wire feed gun and or torch it may be diffacult to figure out.Here is a Gilliland Mig gunhttp://www.theweldingstore.com/Merch...ode=TWS-350I-GA photo of Bob Gilliland who used to be a test pilot standing by a SR-71 blackbirdhttp://www.wvi.com/~sr71webmaster/gilliland003.jpgLast edited by Donald Branscom; 05-10-2008 at 03:38 AM.
Reply:OK...Here is the main website. http://216.135.251.82/gillilandweaver/Gilliland.htm
Reply:It looks to me just the + comes out of the machine.  The power in goes in the back.  I wonder if it will do pulsed spray mig?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I should have been on this site years ago. You guys are great, Thanks. Here is a picture I found online    http://weldinglab.mma.edu/weldlab/gmaw.html Here is a picture of the gun that came with the machine. I don't see a name or number on it. Any more info, experience or expertise is much appreciated. Thanks, Sean Attached Images
Reply:I know this is an old thred, but I just bought a Gilliland wire feeder, and have been in contact with Ken Gilliland and hes been very helpful. You can call him at 770-487-7942 extension 201. Leave a message and im sure he will call you back, He's called me back the couple times i have needed info, and you can order parts through him as well. .
GMT+8, 2025-12-20 17:20 , Processed in 0.285860 second(s), 18 queries .
