Found bottle?
发表于 2021-9-1 00:47:20 | 显示全部楼层 |阅读模式
I found a Acetylene bottle on the side of the road the other day how can I find if it is a owner bottle or rented bottle? Thanks
Reply:What size, was there a cap on it, what did you do with it? Acetylene is the one to be careful with.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I think it's mine.  Welcome to the forum foulwaters.Rental tanks typically state "Property of (name of welding supply company)" in raised letters around the neck of the cylinder just under were the cap screws on.You may be able to determine where it came from if the stick-on DOT label is still attached which usually has the welding supply information on it.  If it was a rental, they'll have a record of the cylinder.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:gee was it full?? Going to be hard to locate the owner of that. Although it sounds like Duanne is willing to take it off your handsCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:or if duanne doesn't want to recycle I am sure lots of folks here could use it.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:If anyone can tell me the location I found it then they can have it back.HaHa Yes it has gas in it alittle more than 3/4 full it has or should I say had a cap on it there is some road rash it has a welding company name stamped on the neck I guess they will get it back after I finish with it. I just wish it was argon I need that more then acetylene we normally use propane to cut with.
Reply:I'd be careful about using that bottle.  If the honey comb is destroyed, you could have a bomb on your hands, particularly if it feels light.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I do not think the bottle is hurt it was at a intersection so it would have fell off at slow speeds and it is very heavy. The paint is just scuffed up no big makes on it from the fall.
Reply:Originally Posted by fowlwatersIf anyone can tell me the location I found it then they can have it back.
Reply:Good try Duane I will just need alittle more info than that before I let you have it back.
Reply:Originally Posted by fowlwatersGood try Duane I will just need alittle more info than that before I let you have it back.
Reply:The driver probably floored it when he saw that cylinder rolling down the highway behind him.  YIKES    How do you explain the missing cylinder?  This scenario in New Jersey would have caused a major HAZMAT or bomb-squad incident.  The highway would be shutdown for a day while a bomb squad inspects and detonates the bottle.   FIRE IN THE HOLE!
Reply:Yup!They would of thought it was an IED or something!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-20 17:21 , Processed in 0.093078 second(s), 18 queries .
