Thinnest you've welded...?
发表于 2021-9-1 00:47:19 | 显示全部楼层 |阅读模式
I've heard that there is a guy, somewhere in the world of welding gods, that can weld 2 cigarette wrappers together? Like the metal foil that the cigs are covered in inside the box. I heard you have to scrape the paper wrapping off of the backing....I've heard of the soda can thing. Where you cut one in half and weld it back together. What about Aluminum foil? Anyone tried it? Is it even possible? Is the foil too contaminated with... whatever?! HAHAWhat's the thinnest anyone's welded before?
Reply:my buddy wayne can make you a potato chip bag out of aluminum foil.....he claims it will hold water too.only thing worse than an ugly woman is an ugly weld
Reply:It's just a "parlor" trick, with no skill involved!---------------John
Reply:Thinnest I ever welded I think I was about 110 lbs.We want to see something like this in the signature line:Lincoln Ranger 250Miller Auto-Darkening Elite HelmetLincoln 100Lincoln MigMiller Spectrum 375Craftsman 8 galllon gas powered compressorLongevity 200amp Tig Welder LT-200D
Reply:It was toilet paperEverybody that knows me, it's pretty certain I'm about the cheapest SOB on the planet.Gettin' back to the TP.........Now, I'm a 4 sheet man, no more, no less.  Need more, go buy a roll of paper towelsHad a major malfunciton one day.  Got caught between the 3rd, and 4th sheet.  Damn stuff ripped right in the middle.Cain't have that crap..........Got out the ol' flux core, and spliced 'er right up.Only problem was, I got a bad case of A rash due to the spatter.  Kinda like Tiiiiitaniaaaam sand paper"Any day above ground is a good day"http://www.farmersamm.com/
Reply:yeah he told me how he does it but ive never had the ambition to try it. i can weld a corner joint with two face shaving blades with a 1/16" tung.....thinnest ive ever welded.only thing worse than an ugly woman is an ugly weld
Reply:Originally Posted by farmersammIt was toilet paperEverybody that knows me, it's pretty certain I'm about the cheapest SOB on the planet.Gettin' back to the TP.........Now, I'm a 4 sheet man, no more, no less.  Need more, go buy a roll of paper towelsHad a major malfunciton one day.  Got caught between the 3rd, and 4th sheet.  Damn stuff ripped right in the middle.Cain't have that crap..........Got out the ol' flux core, and spliced 'er right up.Only problem was, I got a bad case of A rash due to the spatter.  Kinda like Tiiiiitaniaaaam sand paper
Reply:Originally Posted by Stack of DimesThinnest I ever welded I think I was about 110 lbs.
Reply:Sam     -  You're twistedA butterfly without wings, is just an ugly bug
Reply:Samm doesn't use a toilet, he just uses his beer cup!Er... wait a minute, on second thought, that was a mouse, Sorry Samm! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Tig'd the edges of 2 razor blades together in a butt joint, that's the thinnest I've dared to try.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:my teacher demo'd pasma arc welding on 2 cig tinfoils... it was pretty cool.
Reply:use both sides...
Reply:My tig only goes down to 5 amps, so I can't weld too thin but here are some .008" razor blades I welded the other day:Soda can:Wish I had a micro tig or a plasma welder. And the welding foil thing is simple, no real skill involved.
Reply:There's actually more experience with this sort of thing on electronics boards believe it or not.   There really isn't a whole lot of time spent in the vast majority of welding tasks to make this a common skill  ( i got the hang of it tig-fixing finely detailed injection molding dies).  With the advent of SMT (surface mount devices) in the electronics trade,  most guys are learning to work with finer instruments and magnification.   What many have discovered, surprisingly, is that excepting DTs, caffiene abuse, crack addiction, or very advanced age, most of us are perfectly capable of transferring macro skills to micro skills in pretty short order.   It's a difference in scale more than technique and our micro motor skills, under some magnification especially, are better than most of us would at first think.With a fine enough tungsten, cup, and rod,  good lower amp control on your machine,  little less argon,  and ideally some magnification on your helmet,  extremely fine welding, just like SMT soldering,  soon seems as natural when your brain adjusts to the scale as welding the bigger stuff.Last edited by frascati; 03-04-2009 at 01:10 PM.
GMT+8, 2025-12-20 17:22 , Processed in 0.107682 second(s), 18 queries .
