Some of us were talking the other day about how they are now using a granite tops for the new table saws that are coming out. One of the guys wondered if you could use a granite top for welding on, providing you didn't have to ground to the table. What are the veiws of the more experinced people on this one. I think it could be done, but could the granite handle it?
Reply:Have you ever had HOT rock or cement explode in your face or knock holes in your hood? Usually from the slag melting out of a cut or washing a weld with a torch, but the point is, if you get that rock HOT enough it will hurt you! I wouldn't be interested in trying it myself. Be interesting what the rest of them have to say tho?Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Yeah, rock-based product rapidly shattering from intense localized heat would NOT be fun.And there is a HUGE difference between putting a hot pan from the stove onto a stone-based trivet and having molten 2500F steel or a 5700F oxy-acetylene flame or a plasma jet hitting that stone. The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by gizzardgutzHave you ever had HOT rock or cement explode in your face or knock holes in your hood? Usually from the slag melting out of a cut or washing a weld with a torch, but the point is, if you get that rock HOT enough it will hurt you! I wouldn't be interested in trying it myself. Be interesting what the rest of them have to say tho?
Reply:I can tell you that my farm is loaded with slate. You want to see and explosion try lining your bonfire pit with slate fill the pit with old pallets and stand FAR~~~~~~~ back. I have some pictures somewhere of that day. We did not know better! one exploded and went Thur a double walled shed.Don't even try it my advise.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Lava rocks won't explode. That is why you can heat them in a fire all day then make a sweat lodge and pour cold river water over the super-hot rocks and not worry about an explosion.If you take an ordinary non volcanic rock (such as granite) and do the same thing, then you will have a chipped tooth or be missing an eye or something like that because the rock will explode.
Reply:Exploding work bench.....wouldn't want to do too much hammering on it either. Imagine a big chunk of it breaking off taking with it the 400 lb anvil you were repairing.......OUCH.....MOTHER F&%#@&!Rotavia
Reply:When I worked with a mason we regularly flame finished granite. Basically you would heat the face with a rosebud to cause the face to spall and give you a rough non slip surface. There was a definite trick to doing this right, just enough heat to get the saw cut surface to flake, but not enough to cause damage or injury. Face shields were a definite requirement.
Reply:OK I think it was a bad idea LOL. But its good to know what can happen. The table saw are get with the granite table on them.
Reply:Table saws with granite tops. Like those granite kitchen tops and "commercial" stoves for those that eat out all the time.
Reply:Originally Posted by DSWTable saws with granite tops. Like those granite kitchen tops and "commercial" stoves for those that eat out all the time.
Reply:I was thinking they would probably be very slick and smooth. A bit heavy for me to lug around on my truck however.
Reply:one of the best things about a steel table is you can tack yer work to it in the position you want..some stuff thats irregulat is near impossible to clamp, its needsto be tacked down... |
