Need help testing a gas welder
发表于 2021-9-1 00:47:09 | 显示全部楼层 |阅读模式
Guys i have a guy that thinks his welder isn't working. Wants me to weld with it. He had a guy tell him that it is welding like it is DC- all the time. I checked the lever and the contacts are working. I am going to weld with it in a little bit.I will let you knowOH by the way Miller Trail Blazer 301G
Reply:What gas is he using?  DC neg is flux core territory.  What are the symptoms?  Most likely, it is either a wire feed issue or too slow of a feed rate.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I am assuming (i know) that it is stick weld (SMAW).Tim Beeker.
Reply:There was nothing wrong with the welder. Guy didn't know how to set up the welder.Dumb ***
GMT+8, 2025-12-20 17:21 , Processed in 0.068403 second(s), 18 queries .
