Mig wire feeder / TIG power supply
发表于 2021-9-1 00:47:03 | 显示全部楼层 |阅读模式
Hi Welders,This may be an oddball idea.I have a Kemppi AC/DC Mastertig 2000 tig machine.I also have an old 100amp Mig thats long overdue for an upgrade.I am on a budget.Here is the oddball idea.Would it be possible to use my tig machine as a power source to a Mig remote wire feeder?The Kemppi is a 240volt AC unit and I can set it for DC stick welding.Would this Idea be achievable? Or just wasting my time?Cheers.
Reply:wasting time.....  Tig is constant current, and mig is constant Voltage.  Do a search and it is a ton of posts covering this topic..I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:You can  use a volt-sensing feeder on constant current to mig with, but I don't think you're going to like it very much.   Search the used market for a small 220v mig.   I see them every day on craig's list for cheap.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-20 18:45 , Processed in 0.091289 second(s), 18 queries .
