Cutting hose reels
发表于 2021-9-1 00:46:59 | 显示全部楼层 |阅读模式
Not sure where this should be posted but iam looking for a hand crank cutting hose reel and would like to know if there are any other brands besides reelcraft that make them. I like the safe t model that reelcraft makes but before i buy it i would like to know if there are any other good ones out there
Reply:check out tidweld.com
Reply:Three from "Up North":http://shellryn.com/http://alumareel.com/or contact Jeff at Weld Alert to see what he has in stockhttp://webpages.411.ca/weldalert/Hope it helps,Later,Jason
Reply:thanks for the help i like the reelcraft but i wish it was a little wider that way it wasnt so tall
Reply:northern tools has a few have there 1/2" x 50' air hose reel works great Attached Images
Reply:search for Reel Tech.  They have truck mounted and shop mounted models. I have a truck mounted reel thats had no problems.  Not cheap though."I'd rather be careful a hundred times as killed once"
Reply:Mine are CoxReels.I have self winding though, not hand wind.I built a rack for the three, 75ft of Oxy/Acyl, 50ft air, 50ft 30amp AC. Beats the heck out of winding hoses and cords!!!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:nice set up, ed macAmerican by birth Southern by the Grace of God
Reply:Would you really use the same type of hose reel for air that you would for acetylene hoses? Just curious, guess if you use the right fittings it would be OK. I don't know - just thought I'd throw that out there..Miller Dynasty 200DXHypertherm PowerMax 45Victor OAIR CompressorLots of blacksmithing tools and other fun toys meant to creatively disfigure, reshape, manipulate and join metal.
Reply:Mtncrawler,No, I didn't use an air hose reel for my oxy/fuel. Cox Reels makes specialty reels for that. I imagine other companies do as well.Here are the pictures of the reels and you can probably see the track/bracket that I made for them. Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I bought a tidweld reel it was cheaper than the reelcraft and i like the lower profile of it
Reply:Originally Posted by mtncrawlerWould you really use the same type of hose reel for air that you would for acetylene hoses? Just curious, guess if you use the right fittings it would be OK. I don't know - just thought I'd throw that out there..
Reply:To clarify what MoonRise said....There ARE reels made for oxy/fuel. They are tried and trued. That is ok.Do not substitue a compressed air hose reel and fittings for oxy/fuel. That is not ok.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-21 12:00 , Processed in 0.091904 second(s), 18 queries .
